Page 1 of 4 1234 LastLast
Results 1 to 13 of 50
Thread: TXV hot swap
    Mar 2010
    Fayetteville, AR
    TXV hot swap
    The company I work for pushes us to do hot swaps on 410 TXV's. I'm not a big fan of doing it this way. I'd like to get others' thoughts/pros/cons on doing this.
    What do you mean by 'hot swap'
    X2
    Toledo, Ohio, United States
    Twilly says they steal it from one house and install it in another and get paid for it.
    Mar 2010
    Fayetteville, AR
    Hot Swap is when we pump down the system into the condensor and leave some pressure in it so we are venting some of the 410A
    They tell us that it is faster this way and we dont have to test with nitrogen or pull it down in a vacuum.
    Quote Originally Posted by Lawrence a View Post
    I've done things this way and can say from experience that it is t a good method.
    Do I right.
    Mar 2011
    If the txv is equiped with mechanical conections , such as chatleff with seals , then there is nothing wrong at all with changing the valve with say , 5 psi on the lines and evap.
    Residential speaking.
    This saves time , avoids contamination , and is perfectly do-able.
    New drier or evacuation not needed.
    Even with zero pounds , Carrier says vapor will still exit for some time , preventing air and moisture from entering. (you can see the fumes)
    Also , you can easily thumb a hole with five pounds.
    Oct 2008
    Cleveland, Ohio
    Last time I checked 99% of us get paid by the hr. I recommend residential, commercial no matter what application pump it down, change the txv, change the drier and vac the system. This leaves little room for error. That's my personal opinion.
    Apr 2011
    New Jersey
    Quote Originally Posted by AiResearch View Post
    Thats what she said!
    Jun 2011
    I have done this once with good results. In the perfect world you would have a filter-dryer already in the lineset to clear your mind.
    However, I must say, I have only seen 1 410a TXV actually fail.
    Jun 2009
    it you have the change the txv because it is malfunctioning possibly from debris changing the lld would be a good thing.
    damm i must be slow not sure if it could change it out with presssure remaining on both sides
    i guess if you leave enough liquid in the system and are not using a torch - i hate that- and have your buddy hold his thumbs over the exposed ends while you are in between his legs it might work.
    i probably have bad luck with these things so i'll recover and my buddy has short arms
    Des Plaines,IL
    Do I right.
    Do you mean mean not?
    Stuart
    Lack of airflow destroys compressors.
    oklahoma city U.S.A.
    That can be a problem..... Do you have your E.P.A. certification? Not trying to be an a**, but venting is against the law. Keep in mind that the E.P.A. will fine your personally. Some people still want to vent that shi* into the atmosphere rather then do it properly. I ain't the E.P.A. police, just sayin...
