I came across a 5 ton Rheem condenser the other day, with a 50 amp min. circuit capacity. It had a 30 amp breaker at the panel. The customer has called the electrician. When they are done., I am going back to resize the wire from the disconnect to the condenser. It is currently running a 10 wire. I'm thinking; at least 8 AWG.
MM#7, my understanding is the electrician only goes to the disconnect, from the breaker panel, and HVAC, goes from the disconnect to the unit; and, since the unit is a 5 ton, and is only, using a 10 AWG wire, I was considering rewiring with at least 8 AWG.
If this is a union job, electricians wire all the way, if its not, let the electrician wire it all the way. Or use the same size he runs to the disconnect.
I'd either let the electrician do the wiring as mentioned above...or, since your not sure of the correct gauge wire, ask him when he's there...
Originally Posted by ladyfire3374:
"I used to wake up excited about the challenges of the day. Now the anticipation level is somewhere between a root canal and a colonoscopy."
Run two 6awg and one 8awg ground. on a 50 amp. cya.
In Ontario, Canada the Hvac tech can wire from the panel (including installation of the breaker) to the ac condenser unit, provided he has a refrigeration license, follows the code and gets an inspection....
Never give up; Never surrender!
2 Tim 3:16-17
Member, IAEI
AOP Forum Rules:
In our neck of the woods here is what wire needs to be on what breaker.
15amp 14Awg
20amp 12Awg
30amp 10Awg
40amp 8Awg
50amp 6Awg
Breaker does not protect equipment as so much as stops the wire from catching fire.
If the unit requires minimum of 50amp I would run 6Awg
You're Only As Good As Your Last Service Call or Install.....Make it Count!
2 Tim 3:16-17
Member, IAEI
AOP Forum Rules:
jmo, that show originates in canada, i think its a canadian thing, ive never seen that in the usa, but i havent been in every house in the us! if i had to take a guess by going horizontal, there more clearance from the floor, just a guess! ps, i wonder if holmes, would ever get a job he bid on, he never likes anything,and his motto, is rip it out, i'm the only guy in the world that can do it right! and most people if they had to pay his rates would be in shock.broke. i watch hisshow less and less, again, he comes off as the only guy in the world that can build anything, finally most people get what they pay for!not always, but the average consumer buys on price!
The poster I referenced is Canadian.
2 Tim 3:16-17
Member, IAEI
AOP Forum Rules:
