Results 1 to 13 of 30
Thread: Wire size
    Jan 2010
    Van Buren Arkansas
    Wire size
    I came across a 5 ton Rheem condenser the other day, with a 50 amp min. circuit capacity. It had a 30 amp breaker at the panel. The customer has called the electrician. When they are done., I am going back to resize the wire from the disconnect to the condenser. It is currently running a 10 wire. I'm thinking; at least 8 AWG.
    Aug 2011
    Smile
    Quote Originally Posted by acts238 View Post
    why don't you just have the electrician do it, he'll be there correct!
    Jan 2010
    Van Buren Arkansas
    wire size
    MM#7, my understanding is the electrician only goes to the disconnect, from the breaker panel, and HVAC, goes from the disconnect to the unit; and, since the unit is a 5 ton, and is only, using a 10 AWG wire, I was considering rewiring with at least 8 AWG.
    Aug 2011
    Confused
    JUST A SUGGESTION, if the electrician, is wiring up to the disconnect and he is already set up, let him spend the 10 minutes to wire in the cond. just a suggestion!
    Jun 2006
    New Jersey
    My first question would be.....why there is a 5ton condenser on a 30 amp circuit. That opens alot of other questions.
    Aug 2011
    Confused
    Quote Originally Posted by ascj View Post
    a possible DIY
    Mar 2011
    far southwest chicago suburbs
    If this is a union job, electricians wire all the way, if its not, let the electrician wire it all the way. Or use the same size he runs to the disconnect.
    Jan 2010
    Van Buren Arkansas
    discovering mistakes
    When I discovered the 30 amp tripped breaker, and checked the nameplate on the 50 amp min. unit. I quickly realized, someone made a mistake.
    Aug 2011
    Angry
    what year unit was it and how long ago was it installed?
    Aug 2008
    S. Grand Prairie
    I'd either let the electrician do the wiring as mentioned above...or, since your not sure of the correct gauge wire, ask him when he's there...
    Originally Posted by ladyfire3374:
    "I used to wake up excited about the challenges of the day. Now the anticipation level is somewhere between a root canal and a colonoscopy."
    801 Del Rio pike Franklin Tennessee
    Run two 6awg and one 8awg ground. on a 50 amp. cya.
    Ontario Canada
    In Ontario, Canada the Hvac tech can wire from the panel (including installation of the breaker) to the ac condenser unit, provided he has a refrigeration license, follows the code and gets an inspection....
    Never give up; Never surrender!
    Southeastern Pa
    Before you increase the wire size, read NEC article 430. It has specific guidance for conductor sizes when feeding motors. And yes, it applies to residential.
