    Mismatched split system question
    Greetings one and all, I'm new here and I'm almost finished with my HVAC/R course at Penn Foster so I'll be entering the field soon. I have two questions: first, will someoneplease offer me some suggestions on what permissions/memberships I should request in order to use this forum as a professional starting out? Second, my dad had his AC replaced a few years ago by a very reputable local company and dad told me last week that they intentionally installed a 3.5 ton compressor and condenser with a 4 ton evaporator. Everything I've read says that all components should be properly matched. Are there instances where a mismatch is warranted or was this just a less than optimal installation?
    Aug 2011
    Confused
    Quote Originally Posted by Goebelje View Post
    a lot of co's do that, me personally it's fine!
    That's fine if it is an approved match by the manufacturer. Many do call for that. Raises the sensible heat ratio a bit so not the smartest thing in a humid climate.
