Results 1 to 10 of 10
Thread: 240-24 volt transformer
08-10-2011, 12:30 PM #1
New Guest
- Aug 2011
- 4
Transformer burnt out (3) - have in-line fuse in 24v side - possible cause??? Also I would like to put an in-line fuse in the 240v side of transformer, what size fuse should I use for the 240 v side???? THANKS
08-10-2011, 01:12 PM #2
You should
have a tech look at the system to determine what is taking out these transformers. Excessive load? Wire shorted?
08-10-2011, 03:27 PM #3
- Jun 2007
- So Cal
- 93
As per the AOP Rules only Professional Members * can reply with
advice to the OP. Anyone may post and ask questions. They may even
question the * member answer but not give advice or expand on the
advice given. Please read these rules for a complete understanding. AOP Rules
For those in our industry who wish to become a Professional Member, please click here and follow the
instructions. Apply for Professional
MembershipLast edited by beenthere; 08-11-2011 at 05:06 AM. Reason: No *
08-10-2011, 08:30 PM #4
Professional Member*
- Feb 2006
- Atlanta,GA.
- 729
MembershipLast edited by beenthere; 08-11-2011 at 05:07 AM. Reason: No *
08-10-2011, 08:47 PM #5
- Jul 2011
- whitman ma
- 6
08-10-2011, 10:36 PM #6
New Guest
- Aug 2011
- 4
Yes I installed an inline fuse to the 24v side did not blow fuse on 24 v side but did burn up 3 transformers!! So should I install a in-line fuse on the 220v side before I blow another transformer?? If so what size fuse for the 220v side?? Incoming volts is 246--using a universal transformer 120/208/220 volts, wire for 220-- May try to wire transformer to 120v - 246v may be too much?? ALSO strange wife was using stove the same time I was burning out transformers-- I turned off all 220 breakers when I was changing transformers-when I turned breakers on, stove display & clock did not come on,but stove burners worked, reset breaker on stove (off for 15 min) clock & display OK now. Is main breaker playing tricks?? THANKS YOU!!!
08-10-2011, 10:47 PM #7
New Guest
- Aug 2011
- 4
08-10-2011, 10:56 PM #8
Banned
- Jun 2005
- Winston-Salem NC
- 1,133
4 or 5 posts, offering DIY advice, and all dealing with potentially dangerous voltages.
That is sort of what we ain't supposed to do, if I understand the rules properly.
And I attempted to report each DIY post but forum software wanted me to wait 60-ish seconds between each report.
So for the record, something is broken, and hopefully it ain't the DIY person's heart when he electrocutes himself messing with stuff he fails to understand.
08-10-2011, 11:21 PM #9
- Jul 2007
- The Hot South
- 869
This thread should be closed as op is DIY asking for line voltage electrical advice.
08-11-2011, 05:08 AM #10
Time to have a qualified service tech look at your system.
Thread closed.
