    Jun 2011
    Currently working in KSA
    Bacnet Syntax Addressing for Siemens Controller PXC100E-D
    device 18100 (Magnum 18100)
    Last updated:Wed Aug 10 08
    IP Address:192.168.1.6
    MAC (hex):00-1B-AE-00-08-33
    object_identifier:device (18100)
    object_type:device
    vendor_identifier:Micro Control Systems, Inc. (0xB5)
    object_name:Magnum 18100
    system_status:Operational (0x0)
    vendor_name:MCS
    model_name:Magnum
    firmware_revision:1.0
    application_software_version:HVAC 07.02-Q
    analog_input:1 ( SUCT PS1)
    object_identifier:analog_input (0)
    object_type:analog_input (0x0)
    event_state:normal (0x0)
    object_name:SUCT PS1
    present_value:35.000
    analog_input:2 ( DISC PS1)
    object_identifier:analog_input (1)
    object_nameISC PS1
    present_value:220.000
    analog_input:3 ( SPAREM-3)
    object_identifier:analog_input (2)
    object_name:SPAREM-3
    present_value:-99.900
    analog_input:4 ( SUCT TM1)
    object_identifier:analog_input (3)
    object_name:SUCT TM1
    present_value:53.000
    analog_input:5 ( DISC TM1)
    object_identifier:analog_input (4)
    object_nameISC TM1
    present_value:189.000
    analog_input:6 ( SPAREM-6)
    object_identifier:analog_input (5)
    object_name:SPAREM-6
    present_value:0.500
    analog_input:7 ( AMPS 1 )
    object_identifier:analog_input (6)
    object_name:AMPS 1
    present_value:105.000
    analog_input:8 ( SSPS 1 )
    object_identifier:analog_input (7)
    object_name:SSPS 1
    present_value:0.000
    I use bacnet explorer to get that data in one controller i need to integrate it with SIEMENs controller PXC100E-D. Anyone know the correct syntax?
    Thanks,
    Jojit
    B=[18100][0,1] WILL GIVE YOU ai#1
    Aug 2009
    Quote Originally Posted by waldoverkill View Post
    I would further extrapolate that it follows this format:
    Variable=[Device_Instance][Object_Type,Object_Instance]
    Jun 2011
    this syntax is working in my other project, it is strange that it give my error in the above Controller.
    many thanks for reply.
    Jun 2011
    Quote Originally Posted by BACnet View Post
    gonna try this syntax on Saturday.
    many thanks for the reply.
