    Jul 2011
    Confused Need 60,000 Btu High Fire BUT 600 CFM Low Fire!
    Heres the meat - just bought a small ski lodge off a friend which a rusted out furnace (think it was a trane but can't recall for sure). Lodge has a real nice control system - has three fireplaces so place is zoned. Actually seeing how well the system worked last winter is reason zoning my primary residence.
    The problem is that unless I want to revamp the zone control what I need is a two stage furnace which on 1st stage delivers 600 CFM or less and on 2nd stage delivers around 60,000 Btuh. Everyone I've looked at on 1st stage run 700+ CFM.
    Thanks!
    American Standard/Trane's 95% 2 stage 60,000 BTU on high can be set to run at 600 CFM when on low fire. That's the lowest possible setting, default is 775 CFM. If you went this route, you'd have to be sure you didn't hit the overheat limit if you set it that low.
    May be others, I just have easy access to this data.
    Apr 2010
    Minnesota
    Do you have something against installing a weighted bypass damper?
    Jul 2011
    Quote Originally Posted by dunkman View Post
    Space limitation. Furnace is installed basically in a closet so would be a butcher job to get one to fit.
