Results 1 to 2 of 2
Thread: Hard Start Kit?
    Oct 2005
    What exactly does a hard start kit do and are they normally part of every heat pump system
    Tyler, TX
    A hard start should have been called an "easy start".
    It ensures that the compressor will start under a load.
    They are always used with reciprocating compressors when the metering device is a thermostatic expansion valve (TEV or TXV, depending on brand name & custom).
    Since a TEV is VERY common on heat pumps, the use of a hard start is required.
    Some scrolls will start without one.
    Your contractor can help you with which models need a hard start.
    They are also used when voltage is borderline low, or if equipment is having trouble starting.
    A hard start is a good thing.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
