Results 1 to 7 of 7
Thread: txv problems
08-09-2011, 12:57 AM #1
- Apr 2010
- 19
txv problems
so do txvs go bad after sometime. i had a service call on a 410a carrier system. suction pressure was low 60 psig. discharge pressure was 235 psig. I let the home owner know her txv was bad and changed it out ran the system in cooling and the ac was cooling.
08-09-2011, 06:55 AM #2
Professional Member*
- Feb 2011
- North East Ohio
- 654
Its a mechanical device with moving parts in it. Yes they can go bad
08-11-2011, 04:12 PM #3
- Jul 2011
- 8
pressures sound low... did you leak check?
08-11-2011, 04:17 PM #4
- Apr 2010
- 19
The house is a track home 5 years old I checked the welds and found no oil staining so I don't think they were leaks
08-11-2011, 04:32 PM #5
- Jul 2011
- 8
once you replaced the txv, what was the subcooling? both pressures were pretty low for 410a
08-11-2011, 04:54 PM #6
- Apr 2010
- 19
Subcooling was 11 degrees and suction pressure was 165 and discharge pressure was 265
08-11-2011, 05:25 PM #7
banned by Admin
- Jan 2011
- 92
Still seems strange. Head pressure seems low. With a suction that high you'd expect to see mid eightees inside. So I'm assuming it was hot out. Is the condenser shaded?
