Results 1 to 7 of 7
    Aug 2011
    gaffers and sattler air handler id
    I have an old gaffers and sattler air handler model # 3535erdc63 that i need to id the tonage for a matching condensing unit (the old condensing unit was stolen).Any ideas?
    Mar 2009
    Triad - North Carolina
    Considering what I am assuming to be the age of the unit (1969 or earlier) a recommended match for the air handler would not be available. If it is really that old you would need to replace the air handler for the sake of efficiency and required ARI matching by the contractor you will hire to do the work.
    Let's see what others may say and possibly correct me on. I could be wrong!
    Yes, I've seen that before and it doesn't mean I like it.
    New indoor and outdoor unit. Nothing made that will match up and work correctly.
    Put a new condenser on a G&S air handler?
    Like putting a new motor in a Vega!
    The Hot South
    If you have a Gaffers and Sattler, it's time for a new air handler!
    So Cal, Maui, & Kauai
    Seriously?
    There's no match for that antique. Time to install new matched system.
    s chester county,pa
    plus you will lose 30% or more capacity with that setup. whole new system is the only choice. there is a white paper on this, forget where it is.
