    Aug 2011
    Unit for upstairs old house?
    Hi. We are considering buying an old house (built late 1800's), wood frame, that has central heat & air downstairs, but not up. The upstairs is only a partial upstairs--at the top of the staircase you can turn either right or left and on each side there is a room I would estimate is about 12' x 12'. These 2 rooms are the only thing upstairs. Both rooms have a fairly large storage space behind them that is accessible through a door--the storage spaces are about the size of a really large walk-in closet and are unfinished--like attic space.
    What we are wondering is, if we bought the house and wanted to use the two upstairs rooms as bedrooms for our boys, what would be the most efficient and least costly way to add heat and air up there? I have seen mention of split systems, ductless systems, etc. and I have no clue what those are. Also, what about the kind of heat/ac units that hotels have? What would be the cheapest and easiest to buy and have installed and would not skyrocket our electric bill when used? We live in the south, so a/c is necessary almost 9 months of the year.
    Any advice would be appreciated. Thanks!
    Rochester, NY, USA
    I would consider buying a different house. Old homes where never designed to handle air conditioning.
    Unless your willing to fork over some serious dollars to "fix" the upstairs issue.
    Old homes have some beautiful architecture and have a "homey" feeling. But getting an upstairs area comfortable is a real challege.
    Good luck to you and your new (to you) home
    Scott Isreal
    Coward County Sheriff ​
    Mar 2009
    Triad - North Carolina
    I agree with jmac00. You will spend more money insulatiing and changing windows than you will to install a heating and cooling system. It's all up to you, any heating or cooling you do there will cost lots in energy unless the house is improved greatly.
    Yes, I've seen that before and it doesn't mean I like it.
