Results 1 to 7 of 7
    Nov 2010
    Missouri
    Armstrong water pump 20 hp
    # 4280 BF 4x3x13 this is one of two pumps that are running until end of month then other one runs. two replacement motors through the years
    now I have a seal out leaking water mix. Before I would use angled steel and get behind impeller and move it off of keyed shaft,I am thinking differently now and do not want to warp impeller. 5 1/2 inch opening. I have motor and part of pump assy to get apart. I thought about an inside puller but not in this small itty bitty Town any suggestions.
    Nov 2010
    Missouri
    I contacted tech support they said I was doing it ok They said two crowbars.
    I also made a tool, Flat metal 1/2 inch thick 1 inch wide and 5 1/2 inches long drilled hole in the middle, using long bolt and nut I put bolt through hole and nut between metal and impeller. Tighten bolt and hold nut from turning it pulls it right off.
    Ontario Canada
    Post a pic, you are after all from the "show me" state....LOL
    Never give up; Never surrender!
    Nov 2010
    Missouri
    The nut was too large to go between shaft and impeller I had to obtain a thinner one. bolt is all thread, another nut welded to rod gave me long bolt with threads all the way up. when pulling I used a flat washer to protect threaded shaft when pulling
    Nov 2010
    Missouri
    Quote Originally Posted by xpuser357 View Post
    here is another pic wire is to hold it at piping next to pumps for future use.
    Nov 2010
    Missouri
    I see alot of views but no one wants to leave a comment, different point of view??
    Nov 2010
    Missouri
    Wow 584 views That is cool!! you need me to show you all another tool I engineered
