    Jul 2009
    midwest
    Need help with carrier timer
    working on carrier 38gf003340 not getting 24v to contactor.not sure how to test timer motor ? appreciate a little help.
    Ontario Canada
    Welcome EH!
    You need to call a pro to help you. There is just too many things that can prevent the voltage from getting to the contactor.
    Never give up; Never surrender!
    Fairfield county Connecticuit
    I would call a pro because if you touch the wrong wires on that you will make the smoke come out of your transformer or blow the fuse. When you get into things with electrical we can not advise unless you are a pro this is not DIY to that extent.
    Jul 2009
    midwest
    thanks anyway
