Results 1 to 8 of 8
    Aug 2011
    5 ton efficientcy loss running a 3/4 vapor line
    I have a Lennox xc17 running on a 3/4inch 40foot run to coil. Lennox recommends at least 7/8 inch and the vapor connection at compressor is 1 1/8 inch.
    How much efficientcy am I losing and will this shorten the life of the compressor.
    Ty.
    Houston,Tx.
    See my newer post.
    Houston,Tx.
    May be more than that, I just look at my mfg. site, with Ruud 3/4" is not even optional for 5-ton only 7/8" for suction is.
    Jun 2008
    phoenix az
    Perfect example of why im not a lennox dealer. To answer your question, it will work but you'll probaly go through compressors like toilet paper.
    Arizona
    Quote Originally Posted by hvacguru69 View Post
    And why would that be?
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Jul 2001
    Gold Coast of Connecticut
    With R 410 the losss will be minimal. Maybe 2-3 psig which is not that much on that gas. R-22 you may see 3% or more loss in efficiency. Your compressor will not care of the suction is a couple of pounds lower due to line loss.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Arizona
    Quote Originally Posted by Freezeking2000 View Post
    And will have better oil return!
    Cincinnati, Oh
    I'd say you'd have decreased capacity loss, not efficiency loss.
    "Just get it done son."
    Dad adjusted
