Results 1 to 7 of 7
    Feb 2005
    Question
    Will there be a difference in a Trane or Rheem heatpump supply temp if all other conditions are the same?
    Apr 2003
    Iowa
    I'd say there would be a difference if you put identical equipment side by side.
    Feb 2005
    which one would be warmer if there was a 70 degree return temp on a 40 degree day?
    Jan 2003
    Kentucky
    freon is a temperature pressure creature,so it therefore,can not be defined the way you are trying.....you should always strive to see a 20 degree temp. drop across coil in summer and a 20 degree temp. rise across coil in winter.....again,temperature and pressure effect your supply air temp.,as does the age of system,are the coils clean?,and what type of metering device is in use?,and blower speed tap?...that being said,20 degree rise/drop can not always be attained,but try to get as close to this as possible
    Unfortunately all else will not be the same.
    Your asking for your house I presume.
    Without installing each one in your house and testing it, no way to know for sure.
    One unit may have a better blower curve, and that one would have a lower output temp, but not be the lesser unit.
    It would more likely deliver more BTU's.
    Trust your contractor.
    SW FL
    Thumbs up Evaluation Complexity
    Do you really care if the RHEEM delivers a
    2'F +/- Higher temperature and Significantly LESS overall heat CAPACITY?
    YES!
    Designer Dan
    I personally find that the higher the SEER the warmer the temp is. Probably from having the large outdoor coil to bring heat in from outside. Also I find that scrolls do a better job of heating in cold weather than recips. I know there is a technical explation but can't recall it. ALSO, make sure blower speeds are set to no more than 400 CFM per ton!
