Results 1 to 2 of 2
Thread: NetView vs WinControl
08-05-2011, 09:32 AM #1
New Guest
- Aug 2011
- 1
I'm new to HVAC systems and my first task is to determine if I should purchase WinControl for our system or stick with the NetView we currently have installed. Can someone explain what advantages I would have with WinControl. I have two KMD-5801 controllers.
08-05-2011, 06:56 PM #2
- Dec 2009
- Fort Worth, Texas
- 142
need to repost this in the controls forum.
i believe net view is a display that has been preprogrammed for the customer to view certain aspects of your control system. you can view temps, pressures, status of motors, compressors or fans. can also give you outputs, pids and variables.
wincontrol is a software that you can install on your pc and you can view everything programmed into your system. you can also have graphic pages created where you see the individual pieces of equipment with its data.
hope this helps
