    Feb 2005
    Question
    Whats everyone opinion if a heatpump is to be installed in Southern IL. 1525 sg ft walk out with conditioned basement.
    What are the advantages of a varible speed indoor fan 1 stage vs. a 2 stage unit or dual fuel.
    Also, Rheem vs. Trane in this situation.
    Can you oversize a 2 stage for heating reasons, with ac on one stage?
    VS is comfort.
    2 stage is also comfort.
    You can't oversize that much, you'll still need a back heat sourse.
    SW FL
    Thumbs up House Details
    3-ton, 2-stage might work for 1,525 S.F.
    Is 1,525 S.F. actually the TOTAL area?
    4-Ton would likely be overdoing it and perhaas result in higher relative humidity than you might wish.
    Load Analysis is needed to determine more specific matches.
    4-ton on first stage would 'act more like' a 3 ton.
    Age: __
    Insulation :
    Ceiling R-30 ?
    Walls R-11
    Windows Area
    North ____ S.F.
    South ____
    East_ ____
    West_ ____
    Opinions DON'T really Count ...
    (but they do 'get you in the ballpark')
    Analysis and matching equipment does!
    [Edited by dan sw fl on 11-12-2005 at 06:29 PM]
    Designer Dan
    In the midwest, 1525 sq ft is 2.5 ton tops. With shade, 2 ton would probably cool the place. 3 ton is unheard of, except maybe with the worst hack. We build our homes better than some areas of the country
    High SEER won't pay around here. Buy it if you want bells & whistles. For comfort, a standard scroll heat pump with variable speed blower will do just fine. If you want better humidity control and the model you choose doesn't have a ramp up mode, put a simple humidistat on it to slow the blower in humid weather.
    Rheem vs Trane is a matter of preference. I don't like a recip in a heat pump, I find a scroll heats better in cold weather. The old Climatuff recip just doesn't put out the toasty warm air like a scroll.
    SW FL
    ..., I find a scroll heats better in cold weather. The old Climatuff recip just doesn't put out the toasty warm air like a scroll.
    You mean 90'F supply air is
    Toasty Warm Air.
    Designer Dan
    Memphis
    [QUOTE]Originally posted by BaldLoonie
    [B]In the midwest, 1525 sq ft is 2.5 ton tops. With shade, 2 ton would probably cool the place. 3 ton is unheard ofQUOTE]
    In Memphis a house with 1525 sq feet better have a 3 ton. If not, there will be some irate people in July when the temps are hitting 100 plus.
    Life is like a jar of jalapenos. What you do today might burn your ass tomorrow.
