Results 1 to 8 of 8
Thread: Long cycling?
    New Haven county, Connecticut
    I was wondering if there is such a thing as long-cycling.
    My Robertshaw t-stats seem to keep the furnace on for an extended period, but only during EER (recovery from setback).
    My old Honeywell used to give the exact cycles per hour it was set for (roughly 6 min. on, 6 min. off, 5 cph), and the Robertshaws are set for oil heat (I have oil forced hot air), but for some reason they seem to keep the furnace on until the air reaches desired tstat temp, without a cycle in between. Since its different than the Honeywell, I wasnt sure if its good, bad, or doesnt matter.
    Thanks in advance!
    -Chris
    Apr 2004
    What kind of work do you expect to get durring the off cycle? The ideal scenerio IS for longer run times.
    Apr 2004
    Dude, you got too much time on your hands if you feel like you need to worry about stuff like this. Get a hobby.
    ...SHEEESH!!!
    Jan 2003
    Long cycles are better than short cycles. When a unit runs for longer periods, it is more energy effcient.
    Jan 2005
    Riverside county
    I've heard of long cycling but I like the short ones better I don't get as tired and it leaves time for my other hobbies such as midget throwing.
    I have plenty of hobbies.
    At 2.50/gallon of oil, I like to make sure everything is running as correctly as possible.
    The more money I can save on heating costs, the more I can spend on my hobbies!
    SW FL
    Set-Back ?
    I believe that
    set-back should be limited to ~7'F.
    Designer Dan
    Apr 2004
    It takes "X" btuhs to heat the space, Too many and you over heat it, too few and you dont heat it enough. What is the difference in producing 100,000 btuhs an hour either in a long burn or many short ones? It still takes the same amount of oil and worse yet, you loose a little efficiency during the warm up for each cycle so save your money and be more comfortable by allowing the unit to run.
