    Apr 2008
    Question Cooling Compressor Pressure Sensors
    I have an odd problem any thoughts would be appreciated.
    I have a set of screw compressors that have suction and discharge ports on the lines with a PV09AV Veris (0-10V) pressure sensor.
    The pressure sensors are setup properly and I have used them many times before. The sensors on the suction side read a negative voltage when the screw compressors activate.
    Anyone have any thoughts on why this would happen, the sensors are 0-10 volts and should not output a negative voltage however when I metered them I read -1.5 volts. The common to the sensors are grounded to the building steel along with the copper refrigerant lines.
    Jun 2010
    S. Texas
    I would try floating the ground and taking a reading. Could easily be something coming from the grounding.
    Central Indiana
    Wink Floating is best
    Quote Originally Posted by snowbertca View Post
    I have always floated ALL inputs. NEVER take to chassis or electrical ground.
    Thanks. Mike
    In my service van checking my lotto ticket
    Quote Originally Posted by JNorton View Post
    Are you able to read the actual pressure with it running? The pressure probably is in a negative/vacuum. I've seen several chillers run in a negative pressure on the suction side.
    "If you can't explain it simply, you don't understand it well enough”
    Albert Einstein
    "Don't you just love when the flames burn off the wiring schematic?" hvacvegas-HTALK member
    On Monday, not even the chickens lay eggs...
Tags for this Thread
