hi all, can a dial timing relay be used to replace a freezer pressure switch? this thought came across when my freezer pressure switch had to be adjusted a few times due to inclement weather conditions. the switch is now faulty and im considering replacing it with a timer that will give me the same freezing time desired as with the freezer switch. Is this replacement possible?
