Page 4 of 7 FirstFirst 1234567 LastLast
Results 40 to 52 of 83
Thread: Trane 410A
  1. #40
    The Hot South
    Im not saying you don't have other problems, but it's normal for a 2 stage system to run continuously during hot weather.
  2. #41
    Phoenix, Arizona
    If that is the case and it kept the house cool during the day I would be OK with that, but I can't get it cooler than 79-80 upstairs when it's over 102 outside or downstairs for that matter. I will drop the temps. down to 77 tomorrow and see if it ever reaches 77 in house. My 1993 R22 carrier kept the upstairs extremely cold until it finally crapped out this year. Actually both 1993 units kept the house very extremely comfortable with temps up the 115.
  3. #42
    The Hot South
    Go ahead and drop the temp to 75 on both units in the morning, see how cold it gets, and report back tomorrow evening.
  4. #43
    Yep, set both stats to 75 or lower in the morning, and see if they can drop and maintain temp for the day.
  5. #44
    Stongsville Oh
    Get a thermometer and read suply air temp from the ahu. Second stage should read lower than first stage. Simulate first stace from the termostat. then simulate second stege at the termostat. You should notice about 5 degrees less with second stage on.
    ckartson
    I didn't write the book I just read it!
  6. #45
    Phoenix, Arizona
    Will drop the temps today
  7. #46
    Phoenix, Arizona
    OK will do that and see what happens.
  8. #47
    The Hot South
    Go ahead and drop the temps now before it gets hot. Don't turn the stats up during the heat of the day.
  9. #48
    Phoenix, Arizona
    OK, they are both set at 75 and it's 88 out right now. High today is 105.
  10. #49
    Phoenix, Arizona
    Quote Originally Posted by ckartson View Post
    When I dropped the temp to 75 from 78, air supply blowing at 62 to maintain 78 and blew out cooler at 56-57 to bring it down to 75. However the true test is when its hot outside over 100 that is when it doesn't seem to keep the house cool and it blows out 68 and up. I'm leaving the thermostats at 75(a first) all day as I'll be home and see what it does this afternoon when it gets 105. It's 88 out right now in Phoenix so it's easier to keep the temp at 75 in the house. Our house has good insulation especially in the attic.
  11. #50
    Phoenix, Arizona
    Quote Originally Posted by R123 View Post
    94 outside and we have a little than higher normal humidity today for hx. 40% right now. The Thermo. are holding at 75. We'll see how they do in the afternoon when it's over 100. (11:00 am)
  12. #51
    Nov 2001
    East Texas
    Smile
    Time to downsize from that Mc Mansion.
  13. #52
    Phoenix, Arizona
    Quote Originally Posted by Timber View Post
    If you mean our house size, hey it took 20 years to buy this house size
