Results 1 to 7 of 7
Thread: NOP
    Apr 2003
    New York
    NOP
    Just curious i had a fellow tech tell me that he had an 70# net oil psi. Today
    My response was did u calibrate your gauges?? And he was working on an rack system.Now , i think i remember some where that u cant have and net oil that high?? i am researching this nowto see if i could find anything on internal relief on compressor(copeland) Have any of u guys seen such high net oil psi??? any replies are thanked in advance.
    Winter Haven, FL
    Yes..there was a bunch of build-up in the oil system
    Nov 2003
    What points did he hook up to?
    Was it a Carlyle Compound?
    Apr 2003
    New York
    Quote Originally Posted by smilies View Post
    regular rack ,copland compressor.he says he was at the suction and pump discharge
    Apr 2003
    New York
    Quote Originally Posted by Joe Harper View Post
    huh
    Winter Haven, FL
    You get a coating of what looks like burned up oil on the insides of the pump discharge line. All that pressure is squeezed into a smaller tube than normal. Saw it on an r22 low temp compressor where the demand cooling seloniod had failed.
    Jun 2005
    Las Vegas NV
    Quote Originally Posted by jaybee View Post
    jaybee,
    The oil pump bypass valve should open at 60 psi. There could be blockage causing the higher pressure or the guages could be off.
    Check out bulletin 4-1166 at this link.
    http://www.hvacrinfo.com/ae_index.htm
