Results 1 to 7 of 7
Thread: NOP
08-03-2011, 06:09 PM #1
- Apr 2003
- New York
- 668
NOP
Just curious i had a fellow tech tell me that he had an 70# net oil psi. Today
My response was did u calibrate your gauges?? And he was working on an rack system.Now , i think i remember some where that u cant have and net oil that high?? i am researching this nowto see if i could find anything on internal relief on compressor(copeland) Have any of u guys seen such high net oil psi??? any replies are thanked in advance.
08-03-2011, 06:24 PM #2
Yes..there was a bunch of build-up in the oil system
08-03-2011, 07:00 PM #3
What points did he hook up to?
Was it a Carlyle Compound?
08-03-2011, 07:26 PM #4
- Apr 2003
- New York
- 668
08-03-2011, 07:27 PM #5
- Apr 2003
- New York
- 668
08-03-2011, 09:24 PM #6
You get a coating of what looks like burned up oil on the insides of the pump discharge line. All that pressure is squeezed into a smaller tube than normal. Saw it on an r22 low temp compressor where the demand cooling seloniod had failed.
08-03-2011, 09:28 PM #7
Professional Member*
- Jun 2005
- Las Vegas NV
- 1,111
jaybee,
The oil pump bypass valve should open at 60 psi. There could be blockage causing the higher pressure or the guages could be off.
Check out bulletin 4-1166 at this link.
http://www.hvacrinfo.com/ae_index.htm
