Results 1 to 13 of 16
    What's the normal regulator settings for an oxygen and acetlyene torch used for hvac brazing??
    Aug 2005
    Depends on the size and kind of tip u use. read the paperwork that comes with it. it will tell you all you need to know
    Oct 2005
    Fairfax, VA
    Never more than 15psi for acetylene. Acet regulators are limited to levels below 15 because it's unstable above that ... meaning explosive. Oxygen usually about 40psi.
    The handle valves are adjusted to give a carburizing flame (slight excess acetylene).
    Jan 2003
    ok
    10-15 acetylene.
    20-30 oxygen
    I normally use 10/20.
    regards,
    kelvin
    Feb 2005
    Dothan, Al
    I set for 5 & 10
    Don't know why you would set any higher
    What size tips do you guys use????
    Richard
    Houston,Tx.
    Originally posted by bornriding
    I set for 5 & 10
    Richard
    Ditto !! Same here!!!! always have
    I set my acetylene for 5 psi and my oxygen for 20 psi. I could probably go lower with the O2 pressure.
    Using higher pressures than that with the tips most people use just makes the flame harder to adjust properly.
    [Edited by mark beiser on 11-11-2005 at 08:42 AM]
    Feb 2005
    small island in the Pacific Ocean
    10/20 works well for me
    Florida
    anything above 20psig oxygen is a waste. 7-8ace,15-20 oxy
    I use
    5 & 15 usually, never give much thought day to day
    Nov 2005
    South Texas
    I just enrolled in a HVAC program and in my safty and install class they are teaching us to use 10 for oxygen and 5 for acetlyene.
    Feb 2005
    5-10/10-20 anything is better than a B tank
    Nov 2005
    Regina, SK Canada
    LOL. True!
