Results 1 to 13 of 13
Thread: Old Peerless won't start
11-10-2005, 06:30 PM #1
- Nov 2005
- 4
Hey Guru's,
I have an old (and I mean old) Peerless TW-3 oil burner (boiler).
We're renting a house, and the landlord is out of town. We got an oil drop (100 gals for a 275 tank), and the burner won't start.
There's a green box on the wall next to the burner, that clicks and hums, but nothing on the burner does anything.
The burner is warm, though, which is weird. It hasn't been on in a couple of months. (we have a gas water heater)
Any ideas on what I can do to reset/check the burner, before having to call a professional? It's going to be cold tonight.
Thanks in advance!
11-10-2005, 06:35 PM #2
call a pro
11-10-2005, 06:35 PM #3
Ideas only.. but we can't tell you how to fix it... sorry
rules.. it is called DIY or Do It Yourself...
hit the link below
thx
11-10-2005, 06:36 PM #4Hey duc
your fast on your mouse tonight!
11-10-2005, 06:36 PM #5Does the burner motor run or just hum?
>>>edit... removed caps
[Edited by jultzya on 11-10-2005 at 10:57 PM]
11-10-2005, 06:38 PM #6
- Nov 2005
- 4
The burner motor doesn't even start. The burner itself makes no noise, but is warm.Originally posted by trey r
DOES THE BURNER MOTOR RUN OR JUST HUM?
Only the green box (labelled mysteriously "Taco") makes noise.
11-10-2005, 06:41 PM #7Well you'd better get a tech out there. Motor is probably locked up.
[Edited by jultzya on 11-10-2005 at 10:58 PM]
11-10-2005, 06:52 PM #8
- Nov 2005
- 4
Ok, that was weird.Originally posted by trey r
WELL YOU'D BETTER GET A TECH OUT THERE. MOTOR IS PROBABLY LOCKED UP.
Oil burner just kicked on for no reason (thermostat was off), and ran for a few minutes. I turned the thermo up (while burner was running), and then it turned off anyway.
Does that mean the motor's fine? Why would it do that?
What the heck?
11-10-2005, 06:57 PM #9you may have a fan limit problem but listen up
these guys are right... you had better get an oil-can man out there. it is much safer...
11-10-2005, 06:58 PM #10If that motor has an internal overload anf the bearings are seizing, it's probably overheating and shutting off.
[Edited by jultzya on 11-10-2005 at 10:59 PM]
11-10-2005, 06:59 PM #11If your not a pro tech you can get hurt or burn down your house. Get a pro.
[Edited by jultzya on 11-10-2005 at 11:01 PM]
11-10-2005, 07:09 PM #12
- Nov 2005
- 4
Thermostat was turned down, green box shut up. I will leave it off tonight (cold already anyway.)Originally posted by trey r
IF YOUR NOT A PRO TECH YOU CAN GET HURT OR BURN DOWN YOUR HOUSE. GET A PRO.
Thanks for the suggestions. I will get a tech out here tomorrow morning.
11-10-2005, 09:08 PM #13
- May 2005
- 996
trey, are we SHOUTING??Originally posted by dademon
taco, taco, taco, where have i heard that before??
oh yeah! the power saver switches!!! roflmao!!! you got problems buddy!!!! payson probably knows all about power saver switchez!!!! hahaha!!
