    Nov 2005
    I just had a 2 stage Bryant furnace installed but the installer only put in a one stage T-stat. Probably because there was only enough wiring for a single stage. I have ordered a Honeywell 8320. I think I need the W2 wire for the 2nd stage heat?. Can I use a Debonair Add-a-Wire to solve the problem instead of installing a new wire?
    Tyler, TX
    That's what its made for.
    Personally, I'd rather pull another set of wires.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Cabot, PA
    Talking
    ditto unless it is a real PITA run the new wire it is your best bet
    Yeah.. the new cable will have several spare wires. Having those present will also allow for features you may want to add in the future- dehumidification, humidification, outside temp sensor, dual fuel, fresh air ventilation, etc. Until everything goes digital, there is going to be a lot of push for more wires as systems get more and more complicated.
