Results 14 to 20 of 20
    michigan
    No drain on the overflow pan? I don't see one. And is that duplex the permanent wiring for the furnace?
    Rapid City, SD
    No need for a drain on the pan he's got a fload switch in there.
    We install float switches, but we also run a drain line from the pan to the outside.
    Get back to work.™
    Is this a remodel or a change out?
    Get back to work.™
    Apr 2003
    California
    nice install, looks good. are you not worried about noise or vibrations since the unit is set on the ceiling joists and not hung from the roof joists ?
    Thibodaux, LA
    I know you guys up North tend to do things different, but here the norm is to build a platform for the equipment in the attic. We never had vibration problems. I think the wood dampens the viration a little. If vibration was a problem vibration isolaters would be used.
    Its a 80% vs with a r/a chase you barely can here it in the living area.
    There is a drain on the emergency pan you can't see it in the pictures. It's on the backside.
    We form and pour the slabs ourselves. I don't like the plastic ones.
    "Football Season again finally"
    Thibodaux, LA
    Change-out
