Page 3 of 3 FirstFirst 123
Results 27 to 35 of 35
  1. #27
    Nov 2000
    Eastern PA
    Well, it doesn't have to be to work, just to keep from damaging the heat exchanger. This is why you don't get long warranties on heat exchangers of packaged gas units where the evap coil is before the heat exchanger.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
  2. #28
    Apr 2003
    Eugene, Oregon
    I am curious if any one ever reads install manuals or are they used primarily for knee pads? Electric air handlers or fan coils always have the coil mounted on the return, fuel burning equipment (residential furnaces) require the coil be mounted downstream of the furnace. If your popping of the high pressure switch and it is a heap pump, explore the reason for this. The location of the coil doesn't matter to the pressure switch unless the coil is after the furnace and both are running (furnace and heat pump). The only reason a coil is mounted after a fuel burning furnace is because of rust. What state is the system in when the HP switch opens? Heat pump running and no fire from furnace just blower? This seems to be simple diag procedure. Good luck
    Proud supporter of Springfield Millers and Oregon Ducks.
  3. #29
    Jun 2002
    Bemidji, Mn
    No the gas isnt running. Damn, anyways I didnt go back, was building a walkin all day, thankfully. Dont know if anyone went yet.
    You picked a fine time to leave me loose wheel...
    http://rapalaguy.spaces.live.com/
  4. #30
    Nov 2005
    Shreveport, Louisiana
    You did say the sytem was going out on High Pressure. Check the reversing valve for proper operation.
  5. #31
    Jun 2002
    Bemidji, Mn
    How would this make it go out on High Pressure? Its hotter than mollases after the txv.
  6. #32
    May 2005
    Grapevine, Texas
    why would you want a heat pump if you had a gas furnace?
    Me:here's your invoice. The total is $$.. Customer:Oh would you check...while your here?
  7. #33
    Grottoes VA
    In some areas of the country electric is cheaper than gas at mild outside temp's.
    Most of our winter averages 40deg's. The heat pump runs anytime it is above 35 deg's and below 35deg's, the gas furnace will run. This is called a dual fuel system.
  8. #34
    Jun 2002
    Bemidji, Mn
    Possibly had an undersized r/a, 8x14. We will see...
  9. #35
    thats it .increase airflow
