Has ANYONE seen a system that had the coil on the return side, actually work. 2 of the guys at the shop are trying to make this work, no space on supply. Went out there tonight and the new trane x14 is tripping on hp. TXV fed, I told them it isnt going to work, pull er out and figure a way to redo the supply.
Uhhh..? Heat pump indoor coil always goes on the return side, maybe I'm confused....
Proud supporter of Springfield Millers and Oregon Ducks.
you said this is a heat pump? on trane airhandlers the coil is on the return end. am i reading this right?
Furnace or Air Handler??
Experience is a hard teacher because she gives the test first, the lesson afterwards". -Vernon Law-
yea but that is beside the point.
Furnace is a Lennox Pulse.
IS THIS A DUEL FUEL SETUP?
Yes it does make a difference you don't put a coil on the return of a gas furnace in Texas.
yes
I agree, you shouldt in any state...
NOPE NOT IN NORTH CAROLINA EITHER.
If the airflow is there it wouldnt matter to the heat pump what side of the furnace the coil is on.
- You may not post replies
- You may not edit your posts
Forum Rules
