    Jun 2002
    Bemidji, Mn
    Thats enough to piss a fella off. After installing a Boiler today, it was poppin the relief after shutting down. No I didnt think to check it at first, took me a good hour. Brand new Extrol 30 with 40 psi instead of 12. I guess from now on Ill check the new ones.
    You picked a fine time to leave me loose wheel...
    http://rapalaguy.spaces.live.com/
    Sep 2001
    East Stroudsburg, PA
    A therm-x-trol charge snuck in.
    Blow it down, move on, put an air gauge on every new tank before you put it on the system...
    New Hampshire
    A few years ago I kept finding them with about 5 psi.
    I started checking them all after the relief valve blew on the first underinflated one.
    They've been right on after a few bad ones back then.
    Central Kansas
    Sounds like you got a X-tank for a water well, not a boiler. Supply house may have grabbed the wrong box. Need to make sure they give you the correct tank and as oil lp man said- verify pressure before turning into system. You're right, it does pi$$ a guy off when that happens.
    Don't confuse me with facts, my mind is already made up.
    Jun 2002
    Bemidji, Mn
    No this is the right one, says 12 psi right on it...
    Someone just overfilled it
