Results 14 to 26 of 34
07-31-2011, 05:05 PM #14
- Apr 2011
- Florida
- 87
i'm not quite sure she knows exactly whats going. or what went down. like i said before
sounds like they see a women and are taking advantage of her.
07-31-2011, 05:06 PM #15
- Jul 2011
- 13
07-31-2011, 07:05 PM #16
Post the model number & brand of coil & condenser.
Always drink upstream from the herd
07-31-2011, 07:42 PM #17
You need the installing company to do a little better job of providing you with accurate information. If it used to be able to cool down inside then it should be able to do it now.
I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
Veto Pro Pak - The best tool bag you'll ever own
07-31-2011, 09:53 PM #18
- Apr 2011
- Florida
- 87
how long has this company been around are they certified these ar questions you ned to ask before you hand over money to someone you dont know. and then let into your house. just saying
Aire Force A/C and heating
Florida
since 1988
07-31-2011, 10:28 PM #19
- Jul 2011
- 13
07-31-2011, 11:04 PM #20
8 years old, wonder why such an early failure. How big is home? Can you share a picture of the unit? Particularly return duct work?
07-31-2011, 11:11 PM #21
If that's an ASFM then it's a plenum type coil IMO a bad choice. Here they are considered a builders model coil.
07-31-2011, 11:44 PM #22
New Guest
- Jul 2011
- upstate ny
- 1
I agree with skippedover ...The two companies will blame each other,any leaks should have been found during leak check and evacuation , you may need to change the line set and should have flushed the evap. So find someone {one company} to do it right.
08-01-2011, 07:23 PM #23
- Jul 2011
- 13
08-06-2011, 07:58 PM #24
- Jul 2011
- 13
08-07-2011, 07:32 AM #25
Do you have any data on the current operation of the system?
You need to find and pay for a good company.
I don't think either one of the companies you hired are any good and you decision was based only on price. My company would have NEVER converted an existing R22 coil to 410. We also would have never put anything other than a verify-able matching coil.
Did you register the 113ANA online to get the 10 year parts warranty? It would also accept registering a matched coil to get 10 year parts warranty on the coil and txv, if you had put a matching coil in
It's not the Brand with the fewest repairs-It's all in the install!!! Attention to detail and using the best materials!
08-07-2011, 10:18 AM #26
- Jul 2011
- 13
