    Jun 2011
    Florida Home: Pool Heat Pump Instead Of DX Cooling
    I am toying with several Ideas regarding how to best cool my home in Tampa.
    I currently have a 4 Ton Lennox Low Budget Split that uses a Highboy in the closet. CHEAP To Install, Expensive to operate
    Since THe unit is Trash & 5 Years old I am in The Planning Stages of A Hybrid Mini Split / Chiller Design. But last night I Started Thinking...... Why not Replace TH Lennox with. "Chiller" or Pool Heat Pump with reversing valve
    INSTANT CHILLER.....
    I Run A 2" Supply Exactly Where the Refrgeration Lines Are Now, I Rip Out The Air Handler and install A Reservoir in this closet Actually. A Hot & A Cold water Reservoir,
    I Then Install Water Cooled Fan powered boxes in ANY Location I Choose simply by running a supply and return, with hydronic balancing ball valve and a solenoid to ISOLATE TH area and also to maintain space temps with a line voltag T Stat controlling the solenoids.
    SOUND ANY GOOD?
    Thanks!
    Mar 2011
    East Coast FL
    Lots of the water source companies offer a water to water heater / chiller.
    Reverse cycle.
    Actually is reversable , where you want the heat.
    You could heat the home too , and chill your pool.
    The pool would be the opposite temp of what you'd want for the seasons?
    The pool would have to be large of you could loose capacity.
    Jun 2011
    I Have no Pool! LOL!
    I Will utilize a Reservoir as my "Pool" inside the closet where the old Air Handler was located. Run 2" PVC To the reservoir and install a float valve to maintain water level.
    Mar 2011
    East Coast FL
    LOL Dont know where I got that from or what I was thinking...
    Ill get back to you on that.
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
