Results 1 to 8 of 8
    Question regarding Hydoronic air supplementing radiant heat. The condensers are spec'ed to be the high SEER Lennox condensers. The plan is to utilize hydro air to supplement the radiant heat. Delivered First Co. handlers that have a top SEER rating of 13-14 while the condensers are approx. 19-21. Does Lennox offer a air handler that can accommandate the hydronic heat.
    You can put a hydro coil on any air handler.
    Would a lennox paired air handler be better to get the most out of the high SEER condensors.
    Its the only way you'll get the seer rating.
    Jul 2003
    The Isle of Long
    I would get someone else to do your specing. Matching the equipment is the proper way to go. A HW coil can be added to the supply duct for heat. An aquastat is commonly used to bring on the fan.
    Learning is a lifelong process
    SOUTH YARMOUTH, MA
    lennox offers am61v varible speed hydro-air handlers that are matched to lennox cond.
    Why do you think the company would order first co. air handlers if we specified the Lennox 21 seer condensors. Should I request they change the air handlers before there installed.
    Jul 2003
    The Isle of Long
    Possibly there not aware of it. But now you can tell them.
