Results 14 to 16 of 16
    Jan 2011
    Are fire dampers expensive/complicated to install?
    What are your thoughts on the Santa-fe compact unit recommended by someone else? I notice it is quite small, which would make it an easier fit in our already cramped furnace room. How big do the ducts have to be coming out of the dehumidifier?
    Madison, WI/Cape Coral, FL
    http://www.santa-fe-products.com/pdf...MPACT_sell.pdf
    The duct kit is 8" duct. Not sure of cost in your area for fire damper.
    This our smallest unit. I am sure it will dramatically improve the humidity level in your basement. If you want whole house humidity control of 50%Rh, the Santa FE advance may be a better choice.
    Regards TB
    Jun 2007
    Minneapolis, MN
    Teddy is right about that. We have had great luck with santafe.
