Results 14 to 26 of 42
    chicago suburbs
    16x25 is more than enough for 1200 cfm. don't worry.
    FILL OUT YOUR PROFILE!!
    midwest
    Originally posted by coolcray3
    so you are going to tell me that if you put a 16x25 filter rack on both sides of any furnace with the proper size duct its not going to beenough.
    No that's not what I'm saying. In your post it liked you suggested almost 2000 CFM could be pulled through a 16x25 filter. If that's not what you were saying I apologize.
    no i was just saying that if the installer put a 16x25 filter rack on a 3 ton system and the ducts are propperly sized to handle it that the system would be fine and it common practice to install a 16x25 filter rack on the side of the furnace that has from 1 1/2 to 3 1/2 tons of cooling installed on it.
    just because it's common practice doesn't mean it's right.
    Central Kentucky
    Exactly,
    The only way to verify that filter is adequate for 1200 CFM is to test either the pressure drop across it or to check the face velocity of the filter.
    If it is not sized big enough which IMO it is not the filtration of that media will suffer & filter bypass will occur if the filter rack is not sealed properly
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
    well i guess your right there and almost every installer out there is wrong.
    Central Kentucky
    I used to do the same thing & not think twice about it, then I started measuring the airflow on what we installed & it was the biggest kick in the teeth I had ever gotten.
    The only way to say it is working properly is to test it & if those installers are not doing that I can safely say they don't have a clue if it's working right.
    well if there wasnot enough air flow you would know as soon as you put a set of gauges on it and checked the pressures. and it still comes down to the fact that the manufactures give you a 15 x 24 knock out area on the unit to install the filter rack and have been doing this for ever.why is that
    Some contractors have ben using a .10 Friction Rate forever,doesn't mean it works properly.
    You need to check the filter PD ,but that won't tell you if it's right either,it's the ESP of the duct "system",compared to the fan chart for that model and the airflow required.
    The velocity along in this case will be to great for good filtration.
    Jun 2000
    WYO
    a pleated filter also has more surface area.
    never say never
    pleated filters also cause more restriction.
    midwest
    Most don't care. I never use the supplied filter racks on installs. You keep mentioning the cut out size on the furnace as only being 14 or 16 x25 and your correct. How we do it is make a transition from the furnace to a larger filter rack, but in 95% of our installs we use a media filter which is done the same way with a transition. Filters being to small are one of the biggest reasons for equipment failure simply because of airflow and the fact that few change filters as often as they should which makes using a smaller filter even worse.
    Central Kentucky
    The manufacturers also set the fan speed for cooling in the high speed setting, does this also mean that is where it is supposed to stay? On variable speed motors the dip switches are set by the manufacturer does that mean we should leave them alone?
    You need to take a look at the recommended face velocities for each type of filter media before you can even begin to size them properly.
    Just because there is a 15 X 24 opening does not mean the filter is to automatically be sized to that opening.
    I would not depend on my gauge readings only to identify an airflow issue either, there are other methods that are much more reliable.
