Results 1 to 13 of 25
Thread: High Limit
    Nov 2003
    Ohio
    How often do you guys find A coils dirty enough to make a furnace go off on high limit? I'm a supermarket tech but I went to school for this stuff too, but don't have as much hands on experience. I found my father in laws furnace going out on high limit and I checked the A coil and it had a pretty solid layer which I brushed off as best as I could. I'm going to pump the condensor down and remove the A coil and hose it down real good. My sister in laws furnace had the same issue years ago, it was full of dryer lint. Thanks
    Houston,Tx.
    That's pretty common if the coil is dirty enough had this happen many times.
    CHICAGO SUBURBS
    I see it a lot on newer const. because they use the furnace for construction heaters[though they are not suposed to].the contractors are taking a big warranty risk by allowing builders to use their equip. this way.
    Some people swear by me and some at me
    why take the coil out when they have chemicals you can spray on and run the cooling and it will do the same thing.
    CHICAGO SUBURBS
    I agree with coolcray. I cut a big enough opening in the plenum to access the entire coil and vac. well and use coil cleaner and rinse untill clean in place.
    Jun 2000
    WYO
    If the filter isnt installed properly, then the A coil becomes the filter.
    never say never
    the most common problem with coils clogged from not changing filter or just taking it out when it is dirty and not putting new one in right away.ahh ill get one later.
    Nov 2003
    Ohio
    I figure that taking it out and putting a water hose to it, after taping up the lines tight, would do a better job would it not? I mean it's dirty enough to go out on limit then it's pretty packed up I figure. I'm I wrong?
    Houston,Tx.
    Nope! can't argue with that.
    thatis pretty dirty but the coil cleaner wil eat that stuff up you will be supprised how clean it will get it
    that coil cleaner is the shit thats what it is for so you dont have to take it out just make sure you get the cleaner for the inside coil they have both out side condenser cleaner also.
    CHICAGO SUBURBS
    An A coil by itself is a pretty good restriction when compared to a furnace only installation. It doesn't take as much blockage as you might think to trip out.think about most systems have duct issues already.Also people love the high merv filters that are so restrictive to an allready bad duct job.put all these together and you've got a high temp. cut out waiting to happen.
    Nov 2003
    Ohio
    Talking
    I think they let there filters go too long, they were hard to change and there was two of them. I put an return grill filter holder in for them so they can do it easier. It's a better design than what they had too, tighter. I hope this does the trick! Don't want to be at the In Laws house all the time!
