Results 1 to 9 of 9
    Jul 2011
    Virginia
    Question about reach in fridge by True Manufacturing
    Hi I have a question I'm trying to charge a reach in but was wondering what the temperature inside the box should be compared to the evap coil temperature. The evap coil temperature is 35 F so what should the ambient inside the box be for a proper charge?
    Under a bridge if things don't pick-up
    Don't go away angry... Just go away.
    Apr 2003
    Maple Grove, MN
    First, clean the condenser.
    Then, check that the doors are closing correctly and that the gaskets are ok.
    Then, if it still doesn't work, either call a qualified tech or send the unit to the junk pile and buy a new one.
    The true cabinets that I've seen are critically charged.
    I pull the charge, evacuate and weigh it back per nameplate.
    Jan 2010
    Quote Originally Posted by HoneyDo View Post
    40
    40* @ a 5*TD or 45* @ 10* TD
    35 deg sst seems kind of high! Evap temp of 25 with 10deg td seems more appropriate
    Jul 2011
    northern Minnesota
    i agree with jpsmith1cm, don't forget about the juice weight in you hoses. battled one for a day or two, did exactly what he suggested, runs like a timex now. another clown topped it off, off the ampmeter, 4 oz overcharged.. and all it probably needed was a good cleaning
    Dec 2008
    Nor•Cal
    Quote Originally Posted by budz View Post
    Reachin = 20 td. Walkin = 10 td.
    Jul 2011
    Virginia
    Thank you so much for the help, in this field it is true we all cannot know it all. thanks again.
