Results 14 to 26 of 26
Thread: Bye Bye Burnham
    naugatuck connecticut
    Cool
    Biggest thing I see wrong is
    A-(osv)wrong place
    B-(no spirovent)
    good job(buen trabajo carlos)
    Kingston, Ny
    Ummm, no, if you use zone valves you don`t need to install flow checks,all your doing is moving the location of the pump.
    My understanding and experiance is that if you install a Circulator on the supply side and zone valves on the return side you will need flow controls on the supply side to prevent creep heat in the zones that are not open.
    We just repiped a home that had that installed by the home owner. Now he has no mo creep heat.
    Happiness is the only good. The time to be happy is now. The place to be happy is here. The way to be happy is to make others so.
    -Robert Green Ingersoll
    Kingston, Ny
    A-(osv)wrong place
    B-(no spirovent)
    I like spirovents also, but with the Peerless they already have a tapping on the boiler for air venting too much redundancy. We have not had any problems
    OSV in the wrong place? That is just the shut off near the boiler. There is another 2 behind the well trol.
    I prefer a valve directly before and after the circ.
    At 2 in the morning I'm a little lazy, so I like it to be easy changing circs, or cartridges.
    Nice install though.
    NJ
    I'd open that 1 1/4" ball valve on the return
    "Peace cannot be kept by force; it can only be achieved by understanding." Einstein
    manitowoc wisconsin
    to heck with the shutoff's use webstone flange valves! http://www.webstonevalves.com/isolator.html
    Take your time & do it right!
    Apr 2004
    Bartlett, IL
    Now those are nice!
    Apr 2004
    Ant time you get to pull a Burnham its a plus, the job looks real good.
    I tend to go the other way though, with pumping away, and any thing with more than 1 zone I upgrade the circulator.
    BJD
    pumping away is from the point of no pressure change, not necessarily meaning away from the boiler. The pressure is lowered on the return side of the circulator every time it starts the way this system is piped. This causes the auto fill to react as if the pressure is low. In time it is possible the pressure relief valve will start to leak. To resolve this move the Xtrol to the inlet side of the circulator so it is pumping away from it. The Xtrol or bladder tank is the point of no pressure change
    al
    Nov 2005
    netherlands\europe
    Question
    hi there,
    Please can somebody tell me why do we in Europe fit the expansiontank in the inletside and you [North America ]put it in the outletside?
    If you put it in the inletside it gets less hot and will last longer, this is maybe not so good for the company, but more relayable.
    Please share youre thoughts whit me..
    Colorado flatland native
    ORDER THIS BOOK!
    Walter Matthau
    Nov 2005
    netherlands\europe
    Lightbulb
    I will order the book, but in the meantime you check this out: http://www.diydata.com/planning/cent...ing/boiler.htm
    Remember the pump is forcing the water trough the system and building up [extra] pressure, so hotter water is forced into the vessel damaging the membrane, you will find probebly more black residue in the water.
    The xp vessel shout be mounted close near the inlet of the pump in order to keep positive pressure in the system.
    At least that is what teachers told us.
    This was a long time ago,i agry, but still why the differends???
    kEEP UP THE GOOD WORK.
    lUC.
    S.E. Pa
    Exclamation venting critique
    Factory chimney must be installed to the listed instructions. Not a clear shot but I don't see a listed ceiling support. Do NOT pack kaowool or anything into stated clearances! This is an extreme fire hazard. As a mfrs. rep. who investigates fires, trust me.
    There should be an 18" clearance to combustibles. That includes the ceiling, PVC pipe, wiring, etc.
    There is no cleanout. In ceiling applications, you'll need a tee and connect to the snout.
    The barometric damper should be located close to the appliance collar.
    If you check the firing rate and look it up in NFPA 31, you'll probably see where this vent is oversized.
    hth
