Results 1 to 1 of 1
07-27-2011, 01:38 PM #1
- Jun 2011
- 19
Load Calculations / Hydrid Mini-Split Heat Pump / Chiller Combo / Residential
Unusual Design to say the least, however I am an Inventor and Entrepreneur, so EVERYTHING becomes a ""PROJECT" The house is roughly 4-5 years old, Well built, other than low budget windows and the HVAC System is a Joke.
Lennox Splits and we are Very Close to the Gulf of Mexico so Everyones coils are DUST.... Except mine... I Protected mine with Cal Shield. But there is no HP Control, only LP.
A Chinese Condenser fan with no oil ports spells Disaster....
So UNLIKE All the Idiot Neighbors.... I Am being Pro-Active and Will Begin a "Phased HVAC Project"
"PHASE 1"
Install Either either a Mitsubishi, Sanyo, or Daikin, Inverter Heat Pump, with 4 Ports on the west side of the 2100 sq ft ranch. Install Two Air Handlers and leave Two Ports for Phase 2.
Install a "Chiller" roughly 1 HP, maybe 2. Utilize Chilled Water for my Invention Shop to Maintain Space temps, Not add the load to the mini split if possible using a water cooled condenser and/ or installing the chiller in the garage. The chiller can provide cooling ANYWHERE. I Simply Cut a hole in the ceiling, install a water cooled fan powered box and a diffuser. DONE....
Phase 2
Install 3 Port unit on East Side to handle the master bedroom and bath, as well as a TV Room.
Phase 3:
Install remaining Units in Bedrooms on West side of the house.
Can Anyone Help In Terms of PROPER LOAD CALCS? This is a KEY Part of a correct installation here in Florida....
THANKS!!
