    in a house, Appomattox, Va.
    I'll bet that worked really great for even airflow over the coil. I've seen this at least 4 times before.
    The new a/h installed by coworkers. Field fab transition but can't see under insulation. Steam humidifier on backside.
    new Heatpump outside
    Col 3:23
    Apr 2004
    Bartlett, IL
    Ahhh, another TRANE unit!
    Which HP unit?
    Why is there insulation wrapped on plenum?
    WTF kinda set-up was that?
    two stage heat pump, R410. Insulation on plenum since all rest was insulated and those steam humidifiers can sometimes condense on the sheetmetal if the space is cold.
    Col 3:23
    Apr 2004
    Bartlett, IL
    Aha, is that the 16i or 19i?
    I went to one of our installs a few years ago. Old air handler & coil just like that. We weren't changing the air handler, just the heat pump & coil. Junior the salesman and boss's son & knucklehead installer were doing the job. Got there to find an A coil sitting in the bottom of the air handler where the V coil used to be. Bout had a stroke I was laughing so hard...
