Results 1 to 4 of 4
    Jul 2009
    Fort Worth, Texas
    LG Ductless Heat Pump
    Here is a Ductless Heat Pump I installed recently. Let’s hear it what do you like/dislike about it?
    Also when I arrived on site the home owner had decided he would hang the cassette... no biggie but no discount tho!
    Pilot Hill,California
    I believe LG requires 6 or 7" clearence from the top of the indoor unit for proper return air circulation across the coil. Might want to check.
    Other than the drain line termination ,the out door looks ok.
    Jul 2009
    Fort Worth, Texas
    Quote Originally Posted by dartbyu View Post
    Actually it's 7.9 inches from the top as a minimum. Also requires 8 feet minimum from the floor but hey what are you gonna do about it? It works and the customer is happy!
    Would you care to elaborate on your thoughts about the drain line?
    On the drain line, i like to terminate closer to the ground so it does not run down the wall and stain. Not saying yours is wrong,and hey if the cust is happy thata what counts
