Results 1 to 7 of 7
    Jul 2011
    Central PA
    Display case frustration
    This is an old upright display case. R22, semi herm with hot gas defrost. No discernible Model or serial. No crankcase pressure regulator. Box temp was high (50*). Superheat would fluctuate between 10 and 16*, suction between 59-62 psig. head pressure was 215psig (appx 107*) with about 8 degrees subcooling. Initially thought the hot gas solenoid may have been leaking through but I didn't see any temperature difference that would indicate that. At any rate, my suction was too high. I'm not sure what is causing this. Ambient in the store was 73*. Any insight would be much appreciated.
    Hmmm.
    What might cause high suction pressure with normal to slightly low head pressure???
    I'd look at the compressor.
    Winter Haven, FL
    Pump down test time...
    high super heater, high box temperature.
    I think liquid volume is not enough. but the head pressure not high. maybe one piston of compressor had short circuit.
    Winter Haven, FL
    Both pistons run off the same motor. You can have a broken rod, and still operate provided the rod broke very near to the crankshaft. If its a k-body, it doesn't have any kind of piston rings, so it will scrape the side of the cylinder and eventually loose capacity.
    Jun 2011
    Barbados
    As the others said sounds like your compressor.
    Jul 2011
    Central PA
    Unfortunately I couldn't do a pump down. The only service valves were @ the compressor. It is a K-body. The comp is also making an odd repetitious clicking sound. I'm thinking I'm going to have to tell my service manager that the compressor is on it's way out. Just wanted to Make sure I wasn't missing anything. Thanks for the replies.
