Results 1 to 2 of 2
    Nov 2005
    HOW DO YOU LOCK OUT THE AUX HEAT FUNCTION IN A CARRIER DUAL FUEL SYSTEM USING THE HUMIDISTAT CONTROLLER,
    THANKS, JIM
    If it is like other Totaline thermostats, that is taken care off automatically when you configure the thermostat for dual fuel. The installation instructions with the stat tell you how to set it up.
    You also need the outdoor temperature sensor for that thermostat.
