Thread: ventor motor
    Apr 2005
    Welland, Ontario, Canada
    4 month old Trane xr90 has ventor motor with bad bearing,
    Is this a common problem?
    A sign of things to come?
    burlington county n.j.
    machines built by humans, once in a while you get a bad part.
    Feb 2005
    Ditto what t527ed said. Just for funnies, you may want to check flue gas temp. Too high temp can shorten motor life. Make sure delta T is within the range for this furnace.
    Good luck...
