Results 14 to 18 of 18
    Wadsworth, OH
    Yes...accessibility is required. The Ten year damper warranty does not imply that they NEVER fail, just very rarely. It's typically the ones you bury above drywall that end up with an issue and then the HO wants someone to pay for the drywall work. If you end up having to conceal them...map it out and spell it out. Our warranty does not cover drywall removal or repair.
    "When you perceive zoning not as a bandage but as an enhancement, you truly understand the dynamics and limitations of forced air heating and cooling"
    Cincinnati, Oh
    Just because it isn't electric, doesn't mean it can't break.
    "Just get it done son."
    Dad adjusted
    Apr 2004
    maybe the OP will come back and clarify it for us.
    actually the company with azeral was just going to hack up the supplies off the existing trunk. with reading this isnt the way to do it. Interesting that this was recommended from a large company here in NJ
    Cincinnati, Oh
    Quote Originally Posted by cas View Post
    What does "hack up the supplies mean"?
    Arzel makes dampers that slide into the supply runs, and there's nothing wrong with it.
    In fact, the majority of times, you have to have indivual dampers for each run, because not all the runs on that trunk serve a particular zone.
    Dad adjusted
    Apr 2004
    Quote Originally Posted by hvacvegas View Post
    they were going to put the arzel dampers into the supply runs but they were going to feed another vent off an existing run
