Thread: pulse G 14
    manitowoc wisconsin
    What is the acceptable leakage rate during a pressure test on a pulse?I.E.1psi in 10 min or less.?I cannot remember & it has been awhile since I have tested one.
    Take your time & do it right!
    Post look in here...
    Don't have a lot of time look in this Service Manual maybe it there...
    http://alltemp-hvac.com/GSR14.pdf
    But to be honest I don't think there is an allowable leak rate on a Pulse!
    [Edited by AllTemp on 11-01-2005 at 11:03 PM]
    AllTemp Heating & Cooling
    South Central Kansas
    Lennox has a new policy...if it's out of warranty...replacew it!
    burlington county n.j.
    pressurize to 4psi if any pressure after 10 minutes it passes. have not seen a bad one yet that would hold pressure more than about 30 seconds. any small leaks are found on test plugs or spark plug,flame sensor
    SE Michigan
    Alltemp, why do you have that annoying advertisment and nothing in your credentials?
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
