Results 1 to 11 of 11
    Nov 2005
    I have a 2year old goodman gmnt high efficiency furnace in my cabin in Northern Wiscconsin. When I purchased it the shop that is now out of business said that if I turn it off completely for the winter that there is a drain or drain pan that must be emptied so it doesn't freeze and cause damage. I looked by the drain hoses and couldn't see anything else that might have water in it. Is there something that needs to be done besides check to be sure the hoses are drained? Thanks!
    If there is a plastic trap assembly, remove it, drain it and tape it on the power switch so you cant turn it back on until you reinstall the trap.
    Nov 2005
    Thanks, is the trap by the drain hoses or somewhere else?
    Rapid City, SD
    Usually it's inside of the furnace towards the bottom of the unit. Follow the pipe/tubing back and you'll see it.
    it's attached to the tubing. one in and one out. if this drains to a condensate pump, do not forget about that as well.
    May 2005
    jultzya, ill handle this one!
    perhaps you should have someone out to look at the furnace. obviously, you arent a tech correct me if wrong
    have the furnace cleaned and checked. the tech should know what to do. this is the best advice i can give you
    site rules say no diy help!!!!!!!
    no balloons?
    May 2005
    Originally posted by jultzya
    (we can't help DIY, due to site rules )
    courtesy of jultzya inc
    Nov 2005
    Okay thanks. The problem is that the nearest goodman tech is 250 miles away. Hopefully someone else can help us.
    Nov 2000
    Eastern PA
    It is the plastic box with all of the hoses connected to it mounted on the outside of the furnace. Disconnect all of the hoses and empty it. As mentioned, don't try to run the furnace without that trap being properly reinstalled or you will ruin the furnace.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    May 2005
    you dont need a 'goodman' tech! just call the local heating and air company!
