Results 1 to 13 of 17
Thread: Tempstar unit
07-25-2011, 03:43 PM #1
- Jul 2011
- 9
Tempstar unit
Hi guys!
I have a Tempstar unit which is about7 yrs old. The problem is that it stays on. I set the thermostat on auto at 78, but once it get there it dosent kick off. What do you guys think is wrong with it?
thanks
07-25-2011, 04:11 PM #2
Could be
almost anything. Does the room temperature go past the setpoint, or does the unit just keep running and not cool? You should contact a service tech and have it checked.
07-25-2011, 04:16 PM #3
- Jul 2011
- 9
the unit cools, it dosent kick off
07-25-2011, 04:25 PM #4
Check the fan switch. Is it in auto?
07-25-2011, 05:43 PM #5
- Jul 2011
- 9
yes, fan switch is on AUTO
07-25-2011, 06:07 PM #6
Does the temp drop below 78? If so, you have a problem. If not, you are fine - it is maintaining.
07-25-2011, 06:13 PM #7
- Jul 2011
- 354
07-25-2011, 06:26 PM #8
- Jul 2011
- 9
@ baldloonie, it stays at 78
@thes the airhandler and compressor stay on. to turn OFF i have to swicth the thermostat to the OFF position. If i dont stop it it stay at 78 all day and all night
07-25-2011, 06:32 PM #9
- Jul 2011
- 354
what happens if you turn it down to 72-74? is your stat heat and cool? if it is ,
what happens if you put the stat on heat but at a low temp. does the coolling inits stop? i have an idea, but i can't help a DIY, most guys will tell you to call a pro. i'll let one of the pro's comment on this issue.
07-25-2011, 06:35 PM #10
- Jul 2011
- 9
i havent tried to put the temp down to 72-74. Yes, it has heat and cool
07-25-2011, 06:45 PM #11
New Guest
- Jul 2011
- 3
batteries
Check the batteries in the thermostat. Sometimes the batteries won't be low enough to show a low battery signal but are low enough to not allow the relays to switch. I am saying this on the assumption that you have a digital thermostat mind you. You might want to check your contactor in the condensing unit too
07-25-2011, 06:46 PM #12
- Jul 2011
- 9
yes it is a digital thermostat, ill check the batteries now
07-25-2011, 06:50 PM #13
- Jul 2011
- 9
ok, i changed the batteries, thermostat shows 82 i set it to 80. lets see if that was the problem
