    Oct 2005
    Hockessin,DE
    If for some reason I set the thermostat higher than outside temp (lets say 85F when I know I'm gonna be away for awhile) - would a heat pump come on and start heating the house in summer to bring it up to 85 (if the outside temp drops to below 85 (such as at night)?
    if so, is there some way to prevent it from doing this?
    thanks this would help me greatly with my decision
    http://www.hvac-talk.com/vbb/showthr...threadid=88466
    thanks yall are GREAT!
    -shaum
    It would only try to heat the house up to the 85 set point if you had the thermostat switched to heat...
    Oct 2005
    Hockessin,DE
    let me get this right...
    so it doesn't go just based on the temp on the thermostat
    i have to manually set it to "heat" mode right?
    Rochester, MN
    Re: let me get this right...
    That's right.. Or unless you have "AUTO" change over on the T-stat.
    Even with an auto changover thermostat, there will be a temperature differential between the cooling and the heating set points.
    A heat pump system turns on and off based on the thermostat setpoint and mode just like any other system that is controled by a thermostat...
    I don't know
    Yes - that goes for any system.
    When the thermostat is set to cool, it will only turn it on when the indoor temperature is lower than that of the setpoint. Secondly, heatpumps only heat when the reversing valve is not energized. (it always is upon a call for air conditioning)
    A thermostat is nothing other than an automatic switch based on temperature.
