Results 14 to 26 of 28
    Central Kansas
    The MAV's are only to be piped using two pipe systems, while the newer AAV units are approved for one or two pipe. We've just put in a few recently. Old habits die hard and the theory of not using inside air for combustion that the homeowner paid to heat is instilled in my mind as the only way to go.
    Don't confuse me with facts, my mind is already made up.
    Clarifiction--Not done yet
    Install is still occuring. HELP!!! please. The unit is a 355AAV so this is approved for the one pipe and air intake method?
    [Edited by acam on 10-31-2005 at 09:24 PM]
    Originally posted by bigbird
    I`m reading the specs on the 355mav & no where in the specs. vent table is there a mention of drawing comb. area from the area around the furnace. All the vent tables call for 2 pipe system.
    I have not looked it up.So lets assume bigbird has his reading glasses on,and isnt playing a halloween prank,and is correct...then you have a code violation that could be handled through the city inspector if need be.
    It would be better to draw combustion air from outdoors.your furnace will thank you.
    in order to use inside combustion air if it is allowed by the manufacturer is if you have enough sq footage in the furnace room unless the door has louvers but you still have to go up to 3 inch if the run is too long or has too many elbows or both it is usally 15 feet and about 4 elbows before you have to go bigger
    Rapid City, SD
    The down sides to not piping in the intake air...
    If there's chemicals in the area, they are sucked into the furnace and burned. This can cause premature heat exchanger wear.
    Also you are sucking air from the house and exhausting it. This is basically is blowing air you paid to heat outside. Also it can cause a slight negitive pressure in the house, which will cause more air to leak through the cracks around windows, doors, outlets etc.
    But if it is indeed only rated for 2 pipes, you'd best use 2 pipes so the warrenty isn't void and it'll pass code.
    Oct 2002
    Yo.... Here!, I'm right here..
    I just looked it up on line pages 16 thru 18 on the installation instructions spec the combustion air and area size, or duct size for tight area.
    This furnace Can be installed either way as stated before, but Bryant is pretty specific about combustion air from indoors
    We use the 2 pipe method for all 90%, and a Concentric Vent kit [ one sidewall or roof penetration ]
    been a Bryant dealer 25+yr
    Apr 2001
    san jose,ca.
    I not only have my reading glasses on i also have a magnifing glass in from of them,but as usual i`m no help .All i deal with is the 355MAV`S NOT THE AAV`S.I still say two pipe only.
    Oct 2002
    Ok I'll repeat this furnace 355AAV is designed for either two pipe or 1 pipe and combustion air from inside the house. I wouldn't do it that way but it is in the install manual. I just downloaded them, from hvacpartners. The very first sentence in the manual says One pipe OR Two pipe
    [Edited by pjs on 10-31-2005 at 10:21 PM]
    Apr 2001
    san jose,ca.
    PJS,your the man..........Good job answereing his question
    & clarify=ing the difference for me, thanks...
    Talking Thanks everyone
    I appreciate the excellent responses. I think I'll pass on telling my father-in-law about the install issues. I don't want to get him overly concerned. And I surely don't want to get too piss at me. I plan on getting a real nice fishing boat when the wife get her cut of the inheritance. Wouldn't want to blow it now
    thats all good pjs but does it tell you how long and how many elbows you can have before going to 3 inch
    Oct 2002
    Ah ulterior motive I like that, sounds as if he's getting a good job, I'd still use the 2 pipe though with a concentric vent kit. JMO even if it cost extra.
    Apr 2001
    san jose,ca.
    I would to, & he would have to look at the vent tables to determine vent size with respect to elevation, 90`s & length.The vent size starts at 1 1/2",2"2 1/2" & 3 ".....
